[Geschlossen] Under extrusion in first 10 layers.
Codido
(@codido)
Hello everybody i need a little bit of help fixing my prusa mk2s.
Generally I print in only pla. My hot end temps range from 190-215 depending on brand color etc. My bed is around 55-65c. I have been having issues for about 5 months that I have tried to fix on my own that I haven't I've maybe had 5 good prints from this machine and its frustrated me to the point of wanting to give up. Here are some of the steps I have taken to remedy the issue.
This problem also happens on several other rolls of pla. This is why I bought a new hot end.
 I have tried using cura simplified 3d slicer pe. I have sliced even a cal cube with a bunch of different setting the same results happen so I know it's not a software issue. The first layer is 100% perfect smooth as silk not to much squish not to little. I have replaced the hot end, ran a pid auto tune after wards, I have completely rebuilt the machine till it was completely perpendicular on the xyz calibration. I have done a flow calibration. I have used dial calipers to measure the extruder hatch bolts to being exactly 13mm. I have tried several different rolls of pla some old some new. I have ran calibration cubes retraction tests heat towers. I have re tightened my belts to the sound of a guitar string. I also pulled marvin and the prusa logo off of the website. I still have the same issue of under extrusion. What am I missing?Prusa troubleshooting
Veröffentlicht : 21/12/2019 7:32 am
NotJannet
(@notjannet)
RE: Under extrusion in first 10 layers.
Well, first of all I'd recommend posting over in the MK2s forum section found here:
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk2-s/
This is the section for the Mini.
Veröffentlicht : 29/12/2019 12:13 am
