random missing layers
Dronah
(@dronah)
new mini+ has some missing layers. there is some extrusion on the missing layers, but not a lot. Is my idler tension wrong? Polymaker PLA filament. printing at 210c default settings. Thank you!
Best Answer by Dronah:
(2) Prusa mini hotend / underextrusion fix - YouTube
I followed this video and it fixed all my problems! The Hulk with supports is before, and without is after. Thank you for all your help.
Napsal : 09/03/2021 6:02 pm
Javacer
(@javacer)
RE: random missing layers
It's possible. Wrong belt tension?
Bad filament dimension?
The photo have very small size...
Napsal : 09/03/2021 7:46 pm
1 lidem se líbí
Dronah
(@dronah)
Sorry for small picture here is a better one. Thank you for your suggestions, but I don't think either of those is the issue. I measured the filament and it was exactly 1.75mm and all of the layers that are extruded correctly are perfectly aligned.
Napsal : 09/03/2021 9:01 pm
Javacer
(@javacer)
Ok. Now I see.
It's bad extrusion. Now You have a under-exctrusion in some layers. First clean hotend head. It's have a two vays.
1. manualy in screen change the hotend temperature to 240-250 deg, and prune filament in other screen where setup extreder value. Set value over 40-50. Wait. And set temp to lovely 230-235. Repeat extrusion. Set normal temp for PLA and repeat extrusion.
2. Set more power in extruder screw. May be filament is very soft. I have'nt this filament in my markets.
3. May be need change PTFE tube.
Often I use first way.
Sumtomes for very hard or soft filaments I change the extruder screw forse.
After 50-70 printed hours I burning print head in open fire, ofcouse it's dangeres and I use the 3M mask with coal filters. Before use open filre on hed, had was uninstall from hotend.
some videos:
- But i don't use cold cleaning, it's may bee damadged the axis calibrating and some printer parts.
- burning nozzle. But burn all plactic is tocsic! I use respirator.
change PTFE tube
Oh, in first time you can added 5-10 degree for PLA, it chahge flow, may be you used very fast printing speed and honentd don't melting PLA in small time. More speed -> more flow mm3 need -> more owerheat in extruder need(experemenal for different PLA and different speed)
Napsal : 09/03/2021 10:18 pm
1 lidem se líbí
Dronah
(@dronah)
@javacer
 Thank you so much! I will try this and give you an update when I’m done.
Napsal : 11/03/2021 12:52 am
Dronah
(@dronah)
Napsal : 16/03/2021 1:40 am
