Rainforest frog stops twice at 56% occouring restart-needing error
Villentretenmerth
(@villentretenmerth)
Utenti
Hi, just assembiled my Mini+ from kit, get a fine PRUSA logo print, updated the firmware and trying to print the Frog. Sadly it twice stuck at 56%, an USB error shows, when I tried to contiune the fatal error "WATCHDOG RESET" with sound alarm comes.
Can you check the g-code file Im using, or advice me somehow? It's the file from delivered USB stick with my Prusa.
Postato : 23/10/2023 4:54 pm
René
(@rene-3)
RE: Rainforest frog stops twice at 56% occouring restart-needing error
Posted by: @villentretenmerth
If you want us to check your gcode file you have to upload it here in zip format.
Try to print this frog, if it does not print either then my advice is to go back to the previous firmware version.
Treefrog_variable_MINI_PLA_1h15m
Postato : 23/10/2023 10:15 pm
Villentretenmerth
Utenti
Thanks for answer @René, I have download a new frog's code from prusa3d.com, flashed another pendrive and got a fine prints now.
Looks like the pendrive itself I get with my prusa was somehow broken.
Postato : 24/10/2023 1:07 pm
