[Rozwiązany] Pursa Mini Plus filament threading issue
Spider_Man42
(@spider_man42)
I have recently got a Pursa Mini Plus and it is having an issue with the filament. When I try to load a new filament it will bring me to a prompt where it asks me to continue and  put the filament into the tube I do so but the filament feels like it clicks into some mechanism and then it doesn't move. It doesn't feed it into the extruder and when I try to unload the filament it doesn't come out. I have to yank the filament out which I am worried that it is ripping off part of the filament and will eventually ruin the intake feed for the filament. Does anyone know how I can fix this or is it better to just send it back and get a new printer?
Opublikowany : 28/03/2021 6:59 pm
Katang
(@katang)
RE: Pursa Mini Plus filament threading issue
First thing I would check is that this screw is flush when filament is NOT loaded.  The screw should be flush with the plastic and not tightened.
Opublikowany : 28/03/2021 7:10 pm
3DK
 3DK
(@3dk)
Two things to try
- ensure you have cut the filament diagonally so the tip of the filament is pointy
- as soon as you ‘press to continue’, give the filament a good push into the tube to get it started.
 Mine usually loads without problem but occasionally it needs a helping hand.
Opublikowany : 28/03/2021 9:52 pm
Spider_Man42
(@spider_man42)
@katang
thank you for the help, it was partially because the screw was too tight and because of debris in the mechanism as well. But it is now working smoothly.
Opublikowany : 30/03/2021 4:05 am
