Prusa mini plus
I need help. I was following directions that came with printer and they are wrong. I put together up until connecting y axis motor. Just looked online pdf and it was updated. So I took the two pieces apart to fit the Y-Axis motor through the new side hole in the electronics however it will not fit. Can I put it through the hole for the lcd cable instead?
Best Answer by BogdanH:
Yes, just use that hole. The only thing that's important is, that the cable doesn't obstruct bed movement.
Postato : 04/11/2021 6:02 pm
[Mini+] [MK3S+BEAR]
Postato : 05/11/2021 8:52 am
