Prusa mini calibration, Z axis fail
Etheon
(@etheon)
Hello everyone!
I just finished to mount my printer (Next time I'll buy the already assembled one!).
I have an issue with the Z axis during the calibration, it makes a weird noise and doesn't move. I can move it with my hands but it's really difficult (I struggled with that several time during the set up).
Here is a small video, the interesting part is at the end
Do you know what could be the issue here?
Thank you!
Napsal : 30/04/2021 4:02 pm
mrstoned
(@mrstoned)
RE: Prusa mini calibration, Z axis fail
Does the Z never move? If so check the z-connector on the board.
If you try and raise the Z by hand to 50 or 70mm, then take the spanner-key and check if the little light on the spinda probe goes on or off.
If it doesn't light up or blink, then check your probe-connector.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Napsal : 30/04/2021 9:47 pm
Etheon
(@etheon)
The Z never moved and I check the connector everythings fine. For the probe, I raised the Z and the light went up, if I move a spanner key in front of it, it will turn off.
So everything seems fine, but the Z axis still not move (although the printer make a weird noise when it need to test the Z axis).
Napsal : 01/05/2021 7:55 am
Etheon
(@etheon)
I found the issue !
2 screws were too tight (manual part 3 step 26). Now the Z axis move easily.
Thank you for your help!
Napsal : 01/05/2021 8:34 am
mrstoned
(@mrstoned)
Excellent. Happy printing.
Napsal : 01/05/2021 9:11 am
Eirlink
(@eirlink)
i think ive a Z azis issue too !
This post was modified před 5 years by Eirlink
Napsal : 03/05/2021 5:32 pm
@eirlink
Yup but we can live with them.
Napsal : 07/05/2021 3:38 pm
Aldo
 Aldo
(@aldo)
If it doesnt work
Hello,
I had problem with Z-axis as well, mine was moving well until the top but I still had a failure in test.
I tried the screws fix (manual part 3 step 26, they can be too tight) but it didn't fix the problem.
In this link they talk about a sensor : https://help.prusa3d.com/en/article/m-i-n-d-a-superpinda-sensor-testing-mini-mini_134021
Mine was working well BUT it wasn't positioned correctly, it was too far from the nozzle (the little gold piece which heats up), so I think z-axis wasn't doing the whole path (the sensor was detecting the bed too fast) . I aligned the sensor with the nozzle (it's easy) and the Z axis test passed!
Napsal : 16/07/2021 7:45 pm
Brandon_DSC
(@brandon_dsc)
This video by Colin Hill helped me resolve my selftest z-axis fail. See the video for details on 2 methods of diagnosis and fix. With mine the mini thinks the threaded rod is slightly too long, so a 6mm stopper to slightly shorten the z-axis travel at the top did the trick. He shares a nice little part to print. I happen to have a wrench handy that I just stick in the way during the test. The z-axis almost never travels all the way to the top during prints so for now I'm ok "cheating" the test like this. Subsequent prints have come out great.
Napsal : 15/04/2022 3:03 pm
2 lidem se líbí
Eighties8
(@eighties8)
Thanks! How in the world did you determine this was the issue? FWIW, I'm failing Z axis test too. Just trying to figure out if this is the problem. How do you know how much torque needs to be applied to these screws?
Napsal : 04/08/2022 1:44 am
Alex Casas
(@alex-casas)
Mine to how do you fix this???
Napsal : 20/09/2023 12:05 am
