Problems with clogged Nozzle
No4
 No4
(@no4)
Hi
I bought 3 Prusa Mini, with 2 I have problems.
In the case of the two mentioned, the printing temperature has to be raised significantly, otherwise the nozzle clogs and the extruder grates the material.
I have to print PLA with 230 degrees, if I lower the temperature  the nozzle gets clogged.
I tried 5 different materials, including the material samples from Prusa.
I opened the extruder and checked for contamination, checked the Bowden cable for resistance, checked the PTFE tube in the hot end, pressed material through the hot end by hand (went very easily),I´ve also done a cold pull…..  everything looks OK
This is how the problem is expressed
When I load new material (PLA) into the printer, I preheat the printer to PLA (215 °).
The material runs through the hotend without any problems and comes from the nozzle.
If I now start printing, the printer cools the nozzle to 170 °, performs the meshbed leveling, and then heats up again to 215 °
if it then begins to print, the nozzle is usually directly blocked, possibly printing continues for a few minutes at the latest, then the nozzle is blocked. (First layer distance fits!)
After a short time it clicks from the extruder, the motor loses steps.
The preload of the ball bearing in the extruder has also been changed several times without success
But if I set the temperature to 230-235 ° after the meshbed leveling, the print runs through without any problems.
If I didn't know better I would say that the hotend is too cool. But that can not really be, because when loading the material with 215 ° it runs through the hotend without any problems.
As I have already written ,3 minis were bought, with 2s I have this problem, one works without any problems.
I own two more Prusas, an MK2.5s and an MK3S with MMU2, so I'm not a newcomer to 3D printers
Does anyone have comparable problems
Ps: Sorry for my bad english, google translator is my best friend
Napsal : 11/03/2020 12:30 pm
1 lidem se líbí
Thingaprint LLC
(@thingaprint-llc)
RE: Problems with clogged Nozzle
@marcus-p3 I am currently having a similar issue with my Mini. I got 3-4 good prints using the default PLA settings in PrusaSlicer, but then prints started to under-extrude. I increased the temperature to 230C and it seemed to work for a few minutes, but then it got worse and now I have to increase the temperature even more just to get PLA to come out. The drive gear grinds away at the filament and adjusting the bearing tension did not fix the problem. I began to suspect that the hotend was not reaching temperature, so I measured with an IR thermometer and the nozzle was only at 120C when the printer display was showing 240C. Like your situation, I am able to load filament, using the built-in routines, but then it fails during printing. I've reached out to support and will post back if I get a resolution. I've been using two Prusa MK3s for years and have not experienced a problem like this before.
Napsal : 01/04/2020 11:02 pm
