Printing lines sounds like snaps of air, gaps in print
Jlainton
(@jlainton)
My mini is working great, honestly, it's been a joy.  But Ive had some thoughts around what I think are air pockets in the nozzle or something.  When printing, I can hear little 'snaps' of air, and if I look where it's printed, it leaves a small gap.  Ive slowed the print down, sped it up, and raised and lowered the Z - but it doesnt seem to make a difference.
It doesnt seem to effect much, but I thought id ask.
Im currently sitting at -1.550, and 99% of the time it looks great.
I print at 100, 75 and 125, no change.
thoughts?
Best Answer by sandysasmita:
Just reduce your retraction from default 3.2mm to 2.0mm it should works for prusa mini.
Opublikowany : 25/02/2023 6:20 pm
sandysasmita
(@sandysasmita)
RE: Printing lines sounds like snaps of air, gaps in print
Opublikowany : 25/02/2023 6:56 pm
Jlainton
(@jlainton)
Ill need to recalibrate after that change, no?
Opublikowany : 25/02/2023 7:36 pm
sandysasmita
(@sandysasmita)
You don't need to calibrate anything, use default settings but only change the retraction length in prusaslicer.
Opublikowany : 25/02/2023 7:39 pm
Don't touch the retraction setting, leave it on default.
Popping and fizzing at the extruder is almost always due to damp filament; as moisture boils off steam pressure messes with the extrusion pressures and causes gaps and stringing.
Dry your filament; look for threads here about the process.
Opublikowany : 26/02/2023 9:57 am
2 ludzie polubili
