Printing handbook question
atomleef
(@atomleef)
 I have a question for  9.4 flex
 "Material can adhere very strongly to the smooth pei sheet and require to use of a glue stick as separator to avoid surfac damage."
Question is how I use glue stick?
Thank you
Veröffentlicht : 11/03/2020 5:12 pm
atomleef
(@atomleef)
RE: Printing handbook question
Add more questions
Topic 10.3 smooth pei plate
Don't clean with ipa when print with path.
Then what I need to use to clean plate instead of ipa?
Thank you
Veröffentlicht : 11/03/2020 5:23 pm
TickTock
(@ticktock)
1) How to use glue stick: Just rub it on the surface where you will be printing.  Doesn't have to be smooth or pretty - the nozzle and filament will push any excess aside
2) Don't clean with IPA:  Wait. Wha???
Veröffentlicht : 11/03/2020 5:52 pm
atomleef
(@atomleef)
@ticktock
Thank you
Oh I see I need to rub glue on plate to prevent model stick to surface.
For do not use ipa clean surface it's shown in page 37. Please look my attached an img.
Thank you
Veröffentlicht : 12/03/2020 1:07 am
NibMaker
(@nibmaker)
@atomleef
PETG & flexibles really likes to stick to PEI so it can potentially damage the smooth PEI sheet when you're removing a finished print form the build surface.
Using IPA on a cold bed removes most oils from the surface of the sheet (such as oils from your finger), and these oils generally reduce adhesion.  So the warning is implying that these oils would be beneficial for removing PETG/flex prints from the smooth PEI sheet.
If you're printing in PLA, then you shouldn't need to worry too much about too much adhesion.
Diese r Beitrag wurde geändert Vor 5 years von NibMaker
Veröffentlicht : 12/03/2020 7:38 am
atomleef
(@atomleef)
@nibmaker
thank you 🙂
Veröffentlicht : 12/03/2020 7:55 am
TickTock
(@ticktock)
Honestly, you should not print PETG directly on the smooth sheet anyway.  Are they seriously recommending allowing finger/handling oils to build up to act as a PETG release agent?  Sounds very unreliable.  Use the textured sheets or gluestick (or tape, or any of various other alternatives folks have come up with) for PETG.  I wipe with 99% IPA between every print regardless of the material (PLA & PETG primarily) and have no issues with adhesion (both MK3 and MINI).  For Flex and Nylon, I have a dedicated plate which I use the gluestick on - I just add more glue where needed between prints.  Occasionally (~every 10 prints or so) I will wash it and start fresh.
Veröffentlicht : 12/03/2020 12:33 pm
atomleef
(@atomleef)
@ticktock
how you wash your plate? after use of glue stick.
thank you
Veröffentlicht : 12/03/2020 1:59 pm
TickTock
(@ticktock)
@atomleef
I just use soap and water, then dry thoroughly.  However, I should restate that for the gluestick I am using a dedicated sheet so don't clean often.  The texture sheet blog says not to expose the textured Prusa sheets to water - not sure about the smooth.  Either way, dry thoroughly.
Veröffentlicht : 12/03/2020 2:15 pm
atomleef
(@atomleef)
Thank you
Veröffentlicht : 12/03/2020 6:37 pm
