pla seems not to stick on underlying layer after 10 to 20 minutes
Hi there, first time prusa user here 🙂
The problem i'm facing is quite difficult to describe so a provide a few pictures:
The first 10 to 20 minutes (this happened after 22 minutes) it prints really flawless but then it looks like the filament wont stick anymore to to underlying layer.
Do you guys and gals know what i'm overlooking here?
Thanks in advance!
Martin.
Best Answer by Turro75:
never seen this behavior, try printing a temptower to ensure the current temperature set is the right one of the filament also check the temp setting in the slicer.
it could be also the nozzle got clogged after few minutes.
RE: pla seems not to stick on underlying layer after 10 to 20 minutes
thanks for the tip!
will try and report back how it‘s going 🙂
hey!
I've increased the temp by 10°, now it's printing like a charm 😀
It was indeed a temperature issue, thank you very much!
