PLA Filament Stuck in Extruder, Won't Pull Out for Replacement
[Rozwiązany] PLA Filament Stuck in Extruder, Won't Pull Out for Replacement
AlexLandherr
(@alexlandherr)
After trying to use up my last bit of remaining filament (Vanilla White Prusament PLA) by printing the mandatory Benchy the filament sensor indicated that I was out of filament and it as expected commanded the extruder to pull back what was left in the Bowden tube but this caused two things I did not expect:
  1. The sensor popped off the end of the tube, I probably didn't fasten it enough.
  2. The remaining filament is stuck in the extruder assembly, a lot of it is still outside of the tube easily grabbed by me.
Below are two images of the current situation:
As the sensor can't detect the filament I can't simply use "Unload filament" or "Change filament" in the Filament menu.
What should I do now? I have another full spool of Prusament PLA ready to go.
Helpful answers are appreciated. I usually respond to Tweets directed at me.OS: Raspberry Pi OS & Windows 10. Programming Languages: Python & Java
Opublikowany : 05/08/2021 1:32 pm
AlexLandherr
(@alexlandherr)
Found Solution, Wasn't Pulling with Plier
I got the stuck filament removed with some pliers. All solved!
Opublikowany : 05/08/2021 3:01 pm
JMH714
(@jmh714-2)
This Title is for sale
You could try heat up and then pull the filament out of extruder. Happened to me when I ran out of spool and small filament got stuck in between feeder and extruder (I don't have filament sensor at that time). I had to heat up the extruder and then pull it out.
But glad that you managed to pull it out.
One time when I attempted to upgrade my MK3S to MK3S+, I took apart the extruder and forgot about filament still inside and it was pain to remove filament from a cold heatend. I used the heater gun on heatend to soft up the filament and removed it. Ugh.
Opublikowany : 10/08/2021 2:03 pm
1 ludzie polubili
