Part Cooling Fan Never Turns On During Print
Pirindirin
(@pirindirin)
I am trying to print (in PLA) some small square post about 30mm high, 5mm wide, and about 5-6mm into the print, the post gets deformed. I guess the best way to describe it is that the square just kinda deforms and takes on more of a circular/globby shape. I noticed that the cooling fan is not turning on at all. I know it has in the past on different prints, but it doesn't appear to at all now. I believe this is causing the globbieness because the temperature is so high due to no cooling on such a small part and the layer times are so short. I performed a fan test in the calibration menu and the fan turns on and passes. I've tried using different PLA presets in PrusaSlicer as well as manually just setting it to always on, even on the first layer, and still it won't turn on.
Is there something possibly wrong with my fan or am I just overlooking something simple?
Napsal : 25/11/2021 5:40 pm
