(neg) -X extrusion ridged/gouged/deep line deposit
Brodo
(@brodo)
Hello all. Can anyone suggest a resolution for this issue? Every move in a -X direction makes this deep line in the center of the extrusion.
The material is brand new and the seal was strong. can't be moist material. I have adjusted the flow rate, I performed a factory reset, I even found a more level location. I manage 4 Prusa Minis along with other printers. My other Minis do not display this.... what should I attempt next?
XYZ Squaring? This printer was recently relocated but the problem did exist prior.
Please see photos,
Brodo
Opublikowany : 13/01/2022 9:01 pm
Brodo
(@brodo)
RE: (neg) -X extrusion ridged/gouged/deep line deposit
Opublikowany : 15/01/2022 1:49 pm
Chris Laudermilk
(@chris-laudermilk)
I haven't seen that on mine, so I'm not sure what could be causing it. That calibration patch looks like your Z adjustment is a little high. What does to bed side of it look like?
Hopefully someone more experienced will chime in.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 17/01/2022 2:31 pm
Bob
 Bob
(@bob-2)
Raise your z-offset by 0.025 or 0.050, you're just a touch too low.
Cheers
-Bob
Opublikowany : 17/01/2022 3:26 pm
