Mini Z axis have a non 90 degree via Y
Hello everyone!
Found a problem when printing tall details.
The Z-axis does not have 90 degrees with the Y-axis. It is tilted towards the screen.
A grounded metal part of the Z-axis may have come across.
Tell me how to fix the problem.
RE: Mini Z axis have a non 90 degree via Y
Nobody will throw any idea?
Ok. Googled..
So. This is not possible with the specific physical design of the printer. The tolerances are very large, it is impossible to set right angles using the DIN 875/0 square. The accuracy class of frame fabrication can only be increased by altering the bed and the z axis on the CNC.
But! There is a software solution that the developers of Prusha for some reason blocked for the end user.
М852 https://marlinfw.org/docs/gcode/M852.html command allows you to adjust the angles of deflection in real time during printing.
Here it is
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/b8bc6da0dcc4ce09650be46f23f646b28d9ff771/lib/Marlin/Marlin/src/gcode/calibrate/M852.cpp
And in the assembly header file it is commented out
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/729d19fde4d22ec28616903a7a5abdcb4dda734a/include/marlin/Configuration_A3ides_2209_MINI.h
// Enable this option for M852 to set skew at runtime
// # define SKEW_CORRECTION_GCODE
#endif
Perhaps this will somehow affect performance, I can’t say with certainty whether there will be problems or not.
But. I rebuilt the firmware after measuring test prints with a different setting.
I have allowed the use of a piece of code related to coordinate recalculation.
#define SKEW_CORRECTION <- made changes, removed //
#if ENABLED (SKEW_CORRECTION)
// Input all length measurements here:
#define XY_DIAG_AC 282.8427124746
#define XY_DIAG_BD 282.8427124746
#define XY_SIDE_AD 200
and put my measurements into variables.
I used last stable version from github.
Build firmware
python utils / build.py --final --generate-bbf --final --bootload yes
I uploaded the .bbf file to the USB flash drive and flashed it.
The print completely satisfied me.
It remains the same to align in Z.
Of course I broke part of the motherboard 🙂 as recommended on the site.
Guarantee? ) Why, if it is impossible to print exactly!
