Mini+ trouble with x axis calibration
rwinters@wsd1.org
(@rwinterswsd1-org)
I have finished building the prusa mini+ printer, but it fails on the x-axis calibration and when printing a 20mm cube, height is fine, length is fine, but the x axis dimension is 17.32mm. Any suggestions.
Thank you,
Postato : 02/03/2022 8:38 pm
rwinters@wsd1.org
(@rwinterswsd1-org)
RE: Mini+ trouble with x axis calibration
1 problem solved. Set screws on pulley were loose and slipping. Rookie move on my part.
X-Axis will still not pass the calibration test.
Anyways, it is usable now....
Postato : 03/03/2022 6:29 pm
Chris Laudermilk
(@chris-laudermilk)
"Set screws, the root of all problems"
You did Loctite those set screws, right?
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Postato : 04/03/2022 3:49 pm
