Mini+ does not turn on
Jernej
(@jernej)
Hey,
I have assembled my new Mini+ printer and haven't any issues with the assembly from scratch, however the whole system does not turn on.
I have checked the fuses and they seem ok. Also I have reconnected most of the cables (to my best knowledge they are the same as in assembly manual), but the result is still the same - there is no sign of life 😉
Is there a led indicator somewhere on the board that is turned on?
What are other possible debugging steps I can make before I order a replacement board?
Thank you in advance!
Napsal : 18/09/2022 6:01 pm
Thomas Lynch
(@thomas-lynch)
RE: Mini+ does not turn on
Make sure that the connectors really connected. Sometimes they take some force to connect. Next you may have a broken wire from the power supply. Remove the power supply connector from the unit and check that there is voltage on the pins also make sure that the AC plug is connected to the power supply.
Napsal : 18/09/2022 8:19 pm
Jernej
(@jernej)
I have reconnected the main connectors and now the printer turns on without a problem: LED lights on the board have turned on, LCD display works and I've printed my first objects 😉
Thank you very much for your kind help!
Napsal : 22/09/2022 2:04 pm
