min temp error for both bed and hotend
St Helena Secondary College
(@st-helena-secondary-college)
Just received my new mini assembled and did test fine stated to do the nut and bolt first print failed after 1 hour min temp error checked wiring all good has the board failed what can I do to fix it any ideas.
Veröffentlicht : 15/07/2020 12:56 am
ManelTo
(@manelto)
RE: min temp error for both bed and hotend
I think the best and quickest it's that you use the prusa chat live
Sorry for my poor English. I try to do my best.
Veröffentlicht : 16/07/2020 8:25 am
Posted by: @st-helena-s
That both thermistors fail at the same time is unlikely, but not impossible.
In which environment do you print (housing, cold environment, drafts ...).
To contact Prusachat you have to login with your account and select eshop. After some seconds the chat window appears on the right bottom.
good luck!
Veröffentlicht : 16/07/2020 9:32 am
good luck!
Veröffentlicht : 16/07/2020 9:33 am
Zoltan
(@zoltan-d-2)
Mitglied Moderator
seems your termistors could be disconnected or broken. Could you describe in more detail what happened and when and attach any picture?
What temperatures are shown after you switch the printer on? Picture?
Veröffentlicht : 17/07/2020 6:29 pm
