Live Adjust Z Offset and PrusaSlicer
Jemison
(@jemison)
Hi all,
Apologies if this has been answered before - but I've had some early success and confusion with my new mini and I'm hoping to get some clarity.
For my first print, I used the sample Prusa logo on the USB key after modifying the Live Adjust Z to ~-.800.  I then also printed a calibration cube I downloaded from TeachingTech - all good.
Then, I took a PrusaSlicer project I did months ago while waiting for my Mini to arrive and sent it to the printer via Octoprint and noticed that the initial layer was scratching the steel sheet - I panicked and reduced the Live Z to ~.500 and although I'm not sure it actually fixed the inconsistency, the print succeeded.
My question is, is Slicer ignoring my Live Adjust - or is there some setting in my printer/filament/etc that is overriding the calibration I did with the samples?  I'm guessing the gcode has something that's altering the starting conditions?
Thanks in advance!
Best Answer by Diem:
Glad to hear it's all working.  If you get more first layer problems or adhesion issues then either show us a first layer calibration or the underside of a failed print.
Opublikowany : 18/12/2021 9:36 pm
Jemison
(@jemison)
RE: Live Adjust Z Offset and PrusaSlicer
Slight correction - I used the First Layer Calibration to ~-.800, not the Live Adjust.   And I only used the Live adjust when I needed to correct it from PrusaSlicer.  Apologies for my confusion.
Opublikowany : 18/12/2021 9:50 pm
David
(@david-15)
Is your "Z-Offset" in PrusaSlicer-->Printer Settings-->General set to zero? Can you paste your startup gcode below?
(FYSA,
This post was modified 4 years temu by David
Opublikowany : 18/12/2021 10:39 pm
Jemison
(@jemison)
Hi David,
Yes, my Printer Settings Z-Offset is 0.
Hopefully this is enough gcode:
; generated by PrusaSlicer 2.3.3+linux-x64-GTK3 on 2021-12-18 at 20:09:46 UTC
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; support material extrusion width = 0.35mm
; first layer extrusion width = 0.42mm
M73 P0 R38
M201 X1250 Y1250 Z400 E5000 ; sets maximum accelerations, mm/sec^2
M203 X180 Y180 Z12 E80 ; sets maximum feedrates, mm/sec
M204 P1250 R1250 T1250 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z2.00 E10.00 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
;TYPE:Custom
M83 ; extruder relative mode
M104 S170 ; set extruder temp for bed leveling
M140 S60 ; set bed temp
M109 R170 ; wait for bed leveling temp
M190 S60 ; wait for bed temp
G28 ; home all without mesh bed level
G29 ; mesh bed leveling
M104 S215 ; set extruder temp
G92 E0.0
G1 Y-2.0 X179 F2400
G1 Z3 F720
M109 S215 ; wait for extruder temp
; intro line
G1 X170 F1000
G1 Z0.2 F720
G1 X110.0 E8.0 F900
G1 X40.0 E10.0 F700
G92 E0.0
M221 S95 ; set flow
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
M900 K0.2 ; Filament gcode LA 1.5
; ; Filament gcode LA 1.0
;LAYER_CHANGE
;Z:0.2
;HEIGHT:0.2
;BEFORE_LAYER_CHANGE
G92 E0.0
;0.2
Opublikowany : 18/12/2021 11:30 pm
Please show us a picture of your first layer Z calibration.
Opublikowany : 19/12/2021 4:19 am
Jemison
(@jemison)
Hi Diem,
I didn't take a photo of the first layer calibration - but here are photos of the prusa logo, and a calibration cube.  The bottom item is the rescued print where I used the live z adjust.  I've since reprinted more items from Prusa Slicer and the first layer seems to be starting correctly.  Maybe it was a fluke or newbie error.
Opublikowany : 19/12/2021 4:42 am
Opublikowany : 19/12/2021 1:35 pm
Jemison
(@jemison)
Hi all,
While doing a little nozzle cleaning, I discovered why it made contact with the bed on my first set of prints - my superpinda sensor wasn't secured and could move just by touching it!  So I must have moved it without noticing or it could have joggled on its own.
I think the instruction "Tighten the screw on the MINI-minda-holder. Do not use excessive force. Otherwise, you can break the printed part." must have intimidated me - that's my excuse I'm standing by it. 🤣
Thanks for all the input.
Opublikowany : 30/12/2021 7:13 am
