Layers not lining up for outermost star of "Twisting Star", but all the other inner stars are lined up just fine
Brian Chang
(@brian-chang)
Miembro
Disclaimer : I'm pretty new to printing, definitely don't have a good grasp of all the terms.
I was printing this Twisting star - I had trouble with the outermost star as it seemed to have a lot of trouble lining up, even for the brim I threw in there (but probably didn't need, given that all the inner stars didn't need brim).
What on earth causes this issue, and why was only the outermost star affected negatively in this way?
Respondido : 06/01/2024 12:23 am
_KaszpiR_
(@_kaszpir_)
If you use defaults in PrusaSlicer without custom gcode then your purge line (on the bottom of the photo) is within print area, and this should not happen, so first you should fix XZ axis alignment.
How to do that, please see step 17, second photo on official page https://help.prusa3d.com/guide/building-your-mini_6384
Respondido : 06/01/2024 8:37 am
Brian Chang
(@brian-chang)
Miembro
RE: Layers not lining up for outermost star of "Twisting Star", but all the other inner stars are lined up just fine
Thanks. I ended up figuring out in general that my X-axis motor pulley was loose, and this was causing alignment issues for every print that I've tried lately.
What's really throwing me off is that the inner stars were fine. I could cut off this outer star and I'd have a pretty good print left.
Respondido : 06/01/2024 9:31 am
