Issues Flashing Firmware with PrusaSlicer
willem123
(@willem123)
I haven't been able to update the firmware on my Prusa Mini. I've tried multiple USB drives and resorted to connecting my computer and using PrusaSlicer. That is not working either. Can anyone shed light on the following Output Log and what I can do to update firmware to be able to use the printer?
Using Port : /dev/cu.Bluetooth-Incoming-Port
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: Could not open port: /dev/cu.Bluetooth-Incoming-Port
avrdude-slic3r done. Thank you.
Napsal : 28/11/2020 4:00 am
RE: Issues Flashing Firmware with PrusaSlicer
Have you seen this knowledge base article?
https://help.prusa3d.com/en/guide/how-to-update-firmware-mini_128421
Napsal : 28/11/2020 12:37 pm
willem123
(@willem123)
@joantabb
I have tried this I keep getting Error! #7 Error mounting USB drive! I have tried three different USB drives. Not sure what else to do to make this printer work?
Napsal : 28/11/2020 3:04 pm
Gordon W
(@gordon-w)
Are the sticks you tried USB 2 or 3, how are they formatted and what size are they?
Napsal : 28/11/2020 7:12 pm
willem123
(@willem123)
I finally got the supplied USB to work after resetting consecutively about 10-15 times. Occasionally, I would see the Flash firmware page, but would bounce to the error message when I clicked on Flash. But it finally worked. Not sure why it was so difficult. Now if I could get the first calibration layer to print correctly!
I also tried a 4G and 8G (not sure if they are 2 or 3) and formatted as MS-DOS (FAT).
Napsal : 28/11/2020 7:19 pm
