Is this belt off ?
Tbzehanz
(@tbzehanz)
Is this belt off ?
I tried to align but can't move the pully more :S
Best Answer by FreestyleEngr:
EDIT: It looks like your pulley is installed backwards on your stepper motor - check the instructions posted below 😉
Hey @tbzehanz, have you checked that against the build instructions?
https://help.prusa3d.com/en/guide/2-yz-axis-assembly_196824 - Start around Step 22
I re-aligned everything by checking my orientation on all my parts (especially the MINI-Y-belt-holder) and making sure I fully seated/installed the belt into the belt holder using one of the small Allen/hex wrenches, I also checked the orientation of the pulley on the stepper motor (see below)
Then I reinstalled everything and tensioned the belt lightly. To fully align things, I loosened the set screws on the pulley just enough where it wouldn't rotate freely, but it could slide in-and-out, I then pushed the axis (build plate) back and forth to find the proper alignment and re-tightened the set screws.
I hope this helps!
Napsal : 20/07/2021 12:10 am
Look at step 23 on:  https://help.prusa3d.com/en/guide/2-yz-axis-assembly_196824
Which way round have you mounted the pulley?
Napsal : 20/07/2021 10:43 am
FreestyleEngr
(@freestyleengr)
RE: Check the assembly Instructions
I hope this helps!
Napsal : 20/07/2021 2:16 pm
Tbzehanz
(@tbzehanz)
Thanks
Thanks for good eyes 😉 fixed 😀
Napsal : 20/07/2021 10:14 pm
1 lidem se líbí
