I can't really figure out how to solve the constant failure of the XY Test
Degonjode
(@degonjode)
Hi, Prusa!
I wanted to get the Test to work, since it blocked the Z-Test and Calibration from happening, but it just constantly fails. I already tried retightening the X-axis belt, but the helper app doesn't give conclusive results, so I made a recording of the XY-test, in the hope that this can be used to troubleshoot what is wrong.
The problem was that I tried printing after a bit and a move and tried to print again. First, the 16 point test failed entirely, which I could fix by readjusting the superpinda, but then it just began printing like half a cm away from the printbed, so I wanted to calibrate, but the above stopped me there.
Opublikowany : 15/05/2026 3:47 pm
_KaszpiR_
(@_kaszpir_)
RE: I can't really figure out how to solve the constant failure of the XY Test
You need to provide direct url to the media, without meta tags because embed is not visible
Opublikowany : 15/05/2026 4:35 pm
2 ludzie polubili
Degonjode
(@degonjode)
Does this work?
Providing a youtube link in case it doesn't
Opublikowany : 15/05/2026 6:45 pm
_KaszpiR_
(@_kaszpir_)
I would start with generic checks https://help.prusa3d.com/article/selftest-failed-mini-mini_112055 especially the grub screws in the shafts of the motor axes, if they get loos then thigs instantly go wrong
Opublikowany : 16/05/2026 6:31 am
