How to access x-axis pulley
T7MaMo
(@t7mamo)
my 'y axis worked lose during shipping and I wanted to verify my x-axis wasn't also lose but dont know how to access the pulley screws. Is there a how-to guide published already for this procedure either from official support or from other users? Searching hasn't found anything so far.
Best Answer by Oxygen:
You can access the screws through this hole (there are 2 screws)
Postato : 11/05/2020 8:40 pm
Oxygen
(@oxygen)
RE: How to access x-axis pulley
Stock MK4S with FW 6.2.6
Postato : 12/05/2020 6:28 am
2 persone hanno apprezzato
Armaan Sengupta
(@armaan-sengupta)
Just to add on, I would recommend using a flashlight to see the set screws better, and you can move the hot end left and right until you see the screw. Also, it uses an M2 Allen key. My self-test was reporting failed for the x-axis until I tightened the set screw and fixed it.
Postato : 01/01/2022 9:00 pm
