How smooth should Y axis be?
nonstopdisco
(@nonstopdisco)
The heat bed carriage moves but it doesn't slide like I expected it to. It slides on its own only when I tilt the entire assembly about 60 degrees.
I lubed according to the instructions, I'd say. And there was excess grease when installing the rods.
Just wondering if I should go back and redo the lubrication before I get further into the assembly.
Napsal : 22/04/2021 5:37 pm
mrstoned
(@mrstoned)
RE: How smooth should Y axis be?
You should check that the robs are paralell to each other.
Perhaps loosen the screws front/back and retight them: move bed all way back then tight screws -slightly-. Move bed front, tight screws -slightly-.
Check movement. If ok, tighten up screws.
Also if you have the belt installed, the motor/belt alignment also introduce a drag on movement.
(Sorry for text and spelling, coding-braing kicked in abit)
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Napsal : 22/04/2021 8:46 pm
nonstopdisco
(@nonstopdisco)
Thanks, good that it can be adjusted without complete disassembly. I've moved on and just hope it works.
Now that I've done the Z-axis bearings as well, I think I probably over-lubed the X-axis a bit. I didn't realize there were 4 sets of holes in the applicator so I pushed out some, turned 90 degress, pushed some more and so on.
Napsal : 22/04/2021 9:28 pm
