Heater block displaced
Christer E
(@christer-e)
Changed nozzle and something went horribly wrong, the heater block is now way lower than the PINDA.  Any suggestion on what to do?Displaced heater block
Napsal : 29/10/2021 1:56 pm
BogdanH
(@bogdanh)
Well, obviously you didn't tighten those three grub screws on heatsink and so complete hotend started to come down.
[Mini+] [MK3S+BEAR]
Napsal : 29/10/2021 4:52 pm
1 lidem se líbí
Christer E
(@christer-e)
Replace?
Probably.  Wierd thing is that I removed them completely but I guess I first had done the damage 🙁 Had some severe clogging problem.
Guess a replacement hoteend is the solution to this?
Napsal : 29/10/2021 5:57 pm
Christer E
(@christer-e)
Replace hotend?
Probably.  Thought I did but guess not.  I assume that a replacement hoteend is the solution to this?
Napsal : 29/10/2021 6:57 pm
you should not need to replace the hot end!
Joan
Napsal : 30/10/2021 12:59 am
