Heat Runaway or Calibration Error?
skalanine
(@skalanine)
I've printed less than 10 items so far (it's new.)
After the first 2-3 prints, I started noticing that no matter what filament I select the temp goes to up 250 and the bed to 90. I can tune it back down but what is causing this?
Veröffentlicht : 31/03/2020 7:52 pm
skalanine
(@skalanine)
RE: Heat Runaway or Calibration Error?
Just to add - my next print I just did I set the bed to 77 degrees. It started fine then 10 minutes later it was at 110 degrees.
Veröffentlicht : 31/03/2020 8:22 pm
Posted by: @skalanine
If you are working with PrusaSlicer you must slice with the right selected filament. Various filaments are already available by default.
Veröffentlicht : 31/03/2020 8:30 pm
@skalanine
Can you please zip the Gcode and post it to the forum.
Veröffentlicht : 31/03/2020 8:45 pm
skalanine
(@skalanine)
Yes, it looks like not selecting the correct material in slicer was the problem. Thank you!
Note to self: It helps to read the manual 🙂
Veröffentlicht : 31/03/2020 9:48 pm
Thanks for 'Fessing up, ' often we don't hear how folk resolve issues... it can be a learning point for others!
Veröffentlicht : 01/04/2020 7:49 pm
