Hardware testing - heatbed failed.
JMH714
(@jmh714-2)
I just ran testing before first print. It test the hardware to make sure everything functional. At first, I had two failure: Y axis and heatbed. I fixed the Y axis by adjust the belt tightness. But I'm not sure how to fix the heatbed since it seems it did not reach 100 Celsius - it only went up to 76 Celsius and then it stopped and declared failure.
How do I fix it?
Thank you in advance.
Respondido : 10/07/2021 3:05 am
RE: Hardware testing - heatbed failed.
First check the connections, both ends, a slightly loose plug can become more so as things warm up.
Respondido : 10/07/2021 11:17 am
Posted by: @jmh714
How do I fix it?
If all the wires and connectors are in order and it still doesn't work, I would contact the prusachat.
Just log in with your Prusa account and select the eshop. After a few seconds the chat window should appear on the lower right corner. If the chat window does not open, disable a possibly activated adblocker or try another browser.
good luck!
Respondido : 10/07/2021 11:39 am
JMH714
(@jmh714-2)
I checked everything - all connectors are good. Still had failure.
So, I follow what @karl-herbert suggested: contact via Prusachat. They asked me if I have steel sheet on and I said no. He suggested me to put it on and it passed.
Seems that I have habit following MK3S steps as not putting the steel sheet during self test. So, Thank you guys. 😊
Respondido : 10/07/2021 7:30 pm
@jmh714
Thanks for the feedback. Often the solution is in front of your eyes, but you don't see it.
happy printing 👍
Respondido : 10/07/2021 7:55 pm
