Gritty Surfaces and Edges
I've been struggling with an issue on my relatively new Mini.
I've been getting a rough gritty buildup on both curved surfaces and sharp edges. I noticed it all over a Mandalorian figure, and it happened for the 4 lowest temperatures on a temperature tower, but then completely went away for higher temperatures (grit not present in the temp tower at the temperature I printed the Mandalorian figure.) It does not appear to be a retraction zit.
PLA, default profiles, Temp Tower was .15mm layer height, Mando was automatic variable layer height. No other noticeable issues with the prints.
Any idea what is wrong here or how to fix this? Thanks!
Respondido : 01/04/2020 9:40 pm
