[Rozwiązany] First selftest had failed, then it was worse
Rabbit1234567
(@rabbit1234567)
Hello,
I have just finished building of my mini+. I ran first self-test, and there were some problems. X-Axis moved one time left, one time right, Z-axis wasn't move at all. Result was "x-axis test failed" and where wasn't any results of z-axis test. Note was to reconnect everything. After I had reconnected everything I started self test again and it was even worse. X-axis had moved one time to left, one time to right, then hit the column and still wanted to go further. I turned off printer, loose a little bit tension of belts and started self-test again. In this case super pinda sensot hit heatbed, squish it, move about 2 centimetres, printer restarted with "super pinda sensor is broken" error.
Does anybody know where I should look for solution of my problems?
Best regards
Opublikowany : 15/04/2023 5:53 pm
Rabbit1234567
(@rabbit1234567)
RE: First selftest had failed, then it was worse
I reconnected everything again and luckily now I have only problem with failed self-test of x-axis. Z-axis doesn't have any self test result. Axis moves normally if I move them from settings level, but self-test is failded.
Opublikowany : 15/04/2023 6:16 pm
René
(@rene-3)
With the use of this info, check that the x axis is not twisted.
Step 5
Opublikowany : 16/04/2023 7:16 am
Rabbit1234567
(@rabbit1234567)
 Hey, problem solved.
The issue was with rods of x-axis. They were not pushed to the end. With help from prusa support I used a lot, lot more force to push rods and it started to print nicely 🙂
Best regards
Opublikowany : 16/04/2023 10:54 am
