first problem was extruder doesnt grip the filament. i had to make the filament end sharp angled. then it worked. second problem: . now i cant take out the filament ;D it says open the loader or so. im pulling but seems like it still stucks in gears
thanks
Publié : 01/07/2021 3:49 pm
RE: first problem was extruder doesnt grip the filament. i had to make the filament end sharp angled. then it worked. second problem: . now i cant take out the filament ;D it says open the loader or so. im pulling but seems like it still stucks in ge...
Have you tried to loosen a bit the extruder idler gear? I've had this problem with a flexible filament which would get jammed in the extruder gear. To pull it out I've had to loosen the extruder idler gear and gently pull the filament out.
Publié : 04/07/2021 7:34 am
1 personnes ont aimé
