first layer issue with printing
Stefan Caporale
(@stefan-caporale)
Membre
got everything assembled ..
bed is level in all directions
I cannot get a good first layer with PLA.  Tried glue stick, hair spray... no dice
z offset -1.284 which seems to big .  I adjust through this test print and it never looks nice.  Tried multiple filament samples
downloaded bigger test pattern and look like below
what should i try next
help
Publié : 05/05/2023 7:35 pm
Walter Layher
(@walter-layher)
RE: first layer issue with printing
It might seem that way, but it is probably not. Try going even deeper until you see an improvement.
Posted by: @stefan-caporale
Publié : 06/05/2023 12:35 am
1 personnes ont aimé
JMH714
(@jmh714-2)
It does look like it's bit high.
When I got my first printer and I had same struggling to get right. When you go through calibration, keep increase till you see a thin line "mild" flat. You probably have to run several calibration to get it right. See this link: https://help.prusa3d.com/article/first-layer-calibration-i3_112364
Publié : 11/05/2023 5:51 pm
rocketArt
(@rocketart)
Membre
It took me at least ten attempts to reach a Z-offset that worked well with my smooth steel bed (currently -1.375) using basic Prusa filament. Even then, the little rectangular flag at the end of the first-layer calibration wasn't what I would call completely solid; it had a very even look to it though, with no lumps or openings.
Publié : 20/05/2023 12:31 am
Tysonsw
(@tysonsw)
Why are you using hairspray, gluestick and what not?
You shouldn't need them when printing PLA on the smooth sheet.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Publié : 22/05/2023 12:44 pm
Ernie Tech
(@ernie-tech)
Like rocketArt, my Z is -1.375 and the prints are very good. I would suggest that setting and not use anything other than the smooth sheet itself. I am using Prusament PLA with all the stock settings
Be the Denisovan in the sea of Neanderthals
Publié : 30/05/2023 1:07 am
