First layer issue
Herr Olsen
(@herr-olsen)
First layer issue
does anybody know why I keep getting first layers with strange spots like in the picture attached?
I tried everything from cleaning the bed ten times in a low to lowering the nozzle until it almost touched the bed but nothing seems to help.
Happens especially with PETG and the textured sheet.
Desperate,
Chris
Posted : 06/03/2022 10:22 pm
Chris Laudermilk
(@chris-laudermilk)
RE: First layer issue
Looks like you are way too low. Raise your live Z a bit.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Posted : 07/03/2022 7:50 pm
The other thing that can contribute to that is bed contamination.  Basically oils from your fingers,  IPA doesnt remove it, it just moves it around.  Unless you use LOTS and lots of ipa.
Posted : 07/03/2022 8:02 pm
Herr Olsen
(@herr-olsen)
OK. Will try.Thanks
Posted by: @chris-laudermilk
Posted : 07/03/2022 9:34 pm
Herr Olsen
(@herr-olsen)
Oh. I always thought IPA would remove skin fat. So dish soap or something different?
Posted by: @neophyl
Posted : 07/03/2022 9:36 pm
sylviatrilling
(@sylviatrilling)
Dish soap and plenty of hot water.
Mk3S+,SL1S
Posted : 07/03/2022 11:01 pm
towlerg
(@towlerg)
I don't know enough to know if this is correct so I go belt and braces, boiling water, soap and a good scrub. When dry, wipe with IPA but only right to left and front to back. Don't know if the IPA makes any difference but I get a realy nice first layer on my glass bed.
Posted : 08/03/2022 10:25 am
IPA dissolves oils into solution.  They in effect spread the oils around into a nice thin layer that is deposited when it evaporates.  So its ok initially but the amount builds up over time until all of a sudden its not ok and you get parts detaching.  Of course some is carried away on a wipe if thats what you are using too so its not like ipa wipes are totally useless.
Dish soaps are a detergent and work differently.  They surround the oils and so when rinsed the contaminants are washed away along with the detergent.  You do need to make sure that your dish soap/detergent is plain though as additives like scents can also cause problems.
I am very careful about touching my sheets, I can get away with a detergent wash once every few weeks with zero IPA used at all.  Even when printing all week.  Its also easier to tell if you have finger oils on a smooth sheet than a textured one.
Posted : 08/03/2022 11:36 am
towlerg
(@towlerg)
but presumably at a much lower concentration.
+1
Posted : 09/03/2022 12:00 pm
