Filament Sensor bug on i3 mk3s.
Andrew Biss
(@andrew-biss)
Hey all, very new user here. I set up my Mk3s in January and managed to print a Benchy without much issue. Now I’m trying to print my own designs and am running into a lot of issues. This particular issue is minor but the easiest to explain.
I can’t get the filament autoload feature to work when the filament sensor is enabled. After selecting the correct filament and preheating, it says something like “click the button and insert the filament”. I do just this and nothing happens.
I figured out that if I disable the Fil. Sensor, the autoload feature then works.
Is this a bug or am I doing something wrong? I think it worked fine the first time I loaded the filament and now it doesn’t. Thanks for the help.
Napsal : 14/03/2020 11:59 pm
Oxygen
(@oxygen)
RE: Filament Sensor bug on i3 mk3s.
You are in the Mini forum. please look for the right subsection.
Stock MK4S with FW 6.2.6
Napsal : 15/03/2020 8:50 am
