Filament is stuck in printer
I was trying to print my fifth print but the filament was cutting in and out. Ive had this problem before and assumed it was jammed so I just heated it up and purged it a couple times and it worked. I'ts been about two weeks since and I'm having the same trouble, only now Im not even able to unload the filament. Whenever I try I can see the gears spinning but the filament isn't moving at all. The filament isn't purging either. Does anyone know how to get the filament out? I'm very inexperienced and would appreciate the help
Publié : 02/05/2021 12:46 pm
RE: Filament is stuck in printer
I push it through with a tungsten rod.
Publié : 09/05/2021 6:15 pm
