Fiber vs metal sheet
kiteslammer
(@kiteslammer)
Anybody knows if there's a difference in thickness, between the metal sheet and the fiber sheet?
I triy to make the first layer adjustment and it was perfect.. then I through the fiber sheet on and it was completely off?? 🤔🤨
Isente the probe supposed to adjust for that?
Postato : 20/01/2020 3:33 pm
Lichtjaeger
(@lichtjaeger)
RE: Fiber vs metal sheet
Which fibre sheet?
Postato : 20/01/2020 5:40 pm
kiteslammer
(@kiteslammer)
The one provided by Prusa..I got the printer second hand but I reckon it's included when you buy it..
Postato : 20/01/2020 5:43 pm
Sfbrain
(@sfbrain)
@kiteslammer
You have a second hand Mini ??
Postato : 20/01/2020 5:44 pm
Lichtjaeger
(@lichtjaeger)
Prusa only sells two kinds of sheets: Both are steel sheets. One with thin textured powder-coated PEI and one with a smooth PEI sticker foil.
Postato : 20/01/2020 5:47 pm
kiteslammer
(@kiteslammer)
Posted by: @steve-4
@kiteslammer
Yes.. Got it from another guy who had it since dec. 😜🤗
Postato : 20/01/2020 6:22 pm
Crawlerin
(@crawlerin)
By fiber sheet you mean powder-coated? The one with rough surface? If yes, then your thinking is correct, there is a height difference. Unfortunately current firmware does not have profiles for sheets yet and you have to afjust it manually.
If you mean any other spring steel plates than smooth green-brown-ish and textured brown, I am not sure what other he could have sold you.
Postato : 21/01/2020 12:32 am
