Factory reset
audric.lima
(@audric-lima)
Factory reset
hello, sorry for the writing but i am french and i use a translator. I want to know how to do a factory reset because my machine does not work on ignition I have a thud that remains continuously I tried the different ways to reset it but nothing helps.
Postato : 16/03/2020 8:31 pm
RE: Factory reset
Posted by: @audric-lima
On the Prusa Mini a factory reset can be performed through LCD Menu - Settings - Factoryreset. This will reset all data to default values.
https://cdn.prusa3d.com/downloads/manual/prusa3d_manual_mini_en_1_01.pdf
Postato : 16/03/2020 9:23 pm
audric.lima
(@audric-lima)
RE: Factory reset
Hey, thanks for your answer but when i turn on my prusa, the lcd directly appear on a screan where it s write " factory reset" with à strident sound.
When i press 'x', their is Block appearing on the screan and go back to 'factory reset'
Postato : 16/03/2020 9:38 pm
RE: Factory reset
@audric-lima
I would contact the Prusachat. Login with your account, select eshop. After a few seconds on the lower right side appears the chatwindow. Dissable all addblocker or similar in your browser.
Postato : 17/03/2020 12:41 am
atomleef
(@atomleef)
RE: Factory reset
another way, try flash your firmware to older version and flash it again to newest version.
just copy desire firmware to usb and select flash firmware. first down grade it, after upgrade to  4.04 version.
Postato : 20/03/2020 6:32 am
StrawberryJim
(@strawberryjim)
RE: Factory reset
I have the Same Problem with my MK3S, did you found any solution?
Postato : 02/09/2022 10:15 am
