Extruder Dribble?
Al Cheddah
(@al-cheddah)
Extruder Dribble?
I tried to run the First Layer Calibration and I noticed as it was getting ready, it started dribbling out a thin line of filament BEFORE it even touched the hotbed.
What else can go wrong with this thing?
Opublikowany : 24/04/2020 6:31 pm
RE: Extruder Dribble?
Not impressed then?
Joan
Opublikowany : 24/04/2020 6:48 pm
delwilson6241@gmail.com
(@delwilson6241gmail-com)
Some stringing is to be expected.   This is a problem with the one brand of TPU (Flex ...) I bought.  Prusa PLA and PETG work well.  Try setting the extruder temperature lower (stay within the recommended range).
Opublikowany : 24/04/2020 7:01 pm
Al Cheddah
(@al-cheddah)
@del-wilson
I've done that. Anything else?
Opublikowany : 24/04/2020 7:10 pm
Profos
(@profos)
@one-man_indie if you load a filament like PLA it heads up to the usual printing temp and primes the nozzle, while running the first layer calibration it lowers the temp to 170°C for mesh bad leveling, while the temp lowers it can ouze out a little bit of filament, because of the nature of being a bowden style printer. Usually this shouldn't be any issue and should be whiped of while it prints the prime/purge line (if the nozzle is already close enough so the filament will stick to the bed).
Opublikowany : 02/05/2020 1:16 am
Al Cheddah
(@al-cheddah)
I got things fixed now, Thaks to customer service.
Opublikowany : 02/05/2020 1:20 am
