Comparison Firmware 4.0.4 vs. 4.0.2 (extrusion problems)
Is there any Quality Assurance (QA) team at the MINI Firmware Team???
Plus: the unload problems with the stuck filament in the PTFE tube is not a problem in the 4.0.2 firmware (many times here in the forum).
A simple print test would show the bug before the firmware release.... i had just problems since 4.0.3
Best Answer by Crawlerin:
Yes, us 🤣
Prusa Mini - FW:4.2.1
RE: Comparison Firmware 4.0.4 vs. 4.0.2 (extrusion problems)
Yes, us 🤣
Did you recalibrate after installing the firmware. I've had to do that with previous updates, and I know others here are recommending it with 4.04
Pete
Pete
Sure. Business as usual. Factory Reset and Calibration after every firmware change.
Fixed in 4.0.5 RC. Thank you!
@dahuafschmied
Where do you find the 4.0.5 RC? I only see their 4.0.4 firmware. https://www.prusa3d.com/drivers/
@tma
https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/4-0-5-rc1-firmware-for-original-prusa-mini-2/ be aware it's only a release candidate at the moment, but I've not seen anybody mentioning problems with it. I haven't received my Mini yet so can't comment from personal experience using it!
@gordon-w
Thanks for sharing 🙂 I´ll try it and see if it also fixes my extruder studder problem.
