Colorisation with transparant filament
Oxygen
(@oxygen)
What can cause these 'colorization' effects in the bottom?
Best Answer by John Doe:
Had same issue. Problem is that any additional layer on existing layer makes the transparency less and less visible. Had to print it one layer on sides that should be transparent. Mine was a statue of a woman.
Stock MK4S with FW 6.2.6
Napsal : 17/05/2020 7:04 pm
John Doe
(@john-doe-3)
RE: Colorisation with transparant filament
Napsal : 18/05/2020 7:26 am
Oxygen
(@oxygen)
I'll try, thank you
Napsal : 18/05/2020 7:46 am
Crawlerin
(@crawlerin)
Would this help?
Napsal : 20/05/2020 12:03 am
