Can not print in right back of the buildplate
Oxygen
(@oxygen)
I have noticed that printing in the right back of the build plate the first layers do not print then I noticed this what should I do to fix this?
youtube link while making this video I made an indentation of the pei sheet 🙁
Stock MK4S with FW 6.2.6
Respondido : 22/04/2020 7:02 am
NibMaker
(@nibmaker)
RE: Can not print in right back of the buildplate
I'm 99% sure when you auto-home and move your hotend like that, the printer doesn't take into consideration your any ABL adjustments (after all, the ABL didn't probe the bed!)
My Mini's bed is also moderately higher up on the back right corner near the corner of the bed wiring harness. Here are some images I saved from my Octoprint Bed Visualizer readings:
https://imgur.com/a/m4KFN4w
You should be able to print a bed leveling test like this one: https://www.thingiverse.com/thing:2187071
Just scale the X & Y dimensions down to 180x180, and set your number of skirt loops to 0.
Respondido : 23/04/2020 5:17 pm
Oxygen
(@oxygen)
Thank you, but that is what I already did
what I have tried: I made a calibration square of 3x3cm and 0.5 mm high and duplicated them in prusaslicer on the 4 corners and the center sliced and placed the usb drive in the printer. Auto homed the printer turn the nozzle temp to 170 degrees and the bed temp to 60 degrees C. Center the printhead to the center of the printbed (so the Minda can warm up) for 3 minutes and then start a normal print (no specific gcode)
The square on the right corner does not succeed at all and the brim does not get printed (nozzle scatches the printbed)
I thought that buying a Prusa meant that these issues were a lot less... I now have a printer with noise on the X and Y axis, under extrusion issues  and the above issue seems that there is no difference between a Prusa and other printers from the east... disappointing experience
Respondido : 23/04/2020 7:29 pm
