Calibration Result - I am not sure this is right!
saulofaria
(@saulofaria)
Well, I have just finished the assmebly of my mini + Kit and now to calibration step and I am little puzzle after a few attempts to troubleshoot.
I am not sure if the result is ok based on the pictures of the samples provided on the documentation but the first line comes out very flat but that side is not mentioned on the prints to know if the level is correct. Is that an good print?
Best Answer by saulofaria:
OK, so the answer is here:
https://help.prusa3d.com/article/xz-axis-skew-correction-mini_158518
Basically the axis where not all aligned.
Posted : 02/07/2022 6:35 pm
AndrewTerry
(@andrewterry)
RE: Calibration Result - I am not sure this is right!
It does look a little bit too squashed... How did the sqaure patch come out? Ideally it should be a single square - no separation of the strands, but at the same time, no (or at least, very slight) ridges on the top surface.
Posted : 04/07/2022 10:30 am
saulofaria
(@saulofaria)
The Square is perfect! Every other line is perfect. Only the initial line of each print which run on the edge of the front of the plate has that squished line, after that all prints are going perfect.
Posted : 04/07/2022 6:24 pm
saulofaria
(@saulofaria)
Posted : 05/07/2022 1:03 am
