Calibration cube doesn't print beyond a few layers
alidaf
(@alidaf)
I tried printing out the test cube following the instructions from https://help.prusa3d.com/en/article/extrusion-multiplier-calibration_2257 but after a few layers the nozzle temperature drops off so nothing is extruded. The print profile is clean apart from the changes that get made after switching to vase mode.
Posted : 19/10/2021 1:35 pm
The first thing to look for is a loose or dislodged plug.  See section 18 and onwards here:
https://help.prusa3d.com/en/guide/5-lcd-assembly-electronics_202703
Posted : 19/10/2021 10:43 pm
alidaf
(@alidaf)
Curiouser and curiouser!
Well, I printed it again via octoprint and it worked fine. I tried twice from the USB and both suffered this problem. I also changed the filament profile back to the default Prusament one, which I thought shouldn't have mattered. I have been using Polyterra, which doesn't need as much heat according to the blurb so the bed and nozzle temperatures were a bit lower, but that's it. So there are a few variables that could potentially highlight an issue or a bug. I'm sure the plugs are ok since I've been printing  a lot of tall pieces lately and I've carried out a check. It's a bit weird if it comes down to the filament profile but probably more worrying if it's an issue with something else, like the USB.
Posted : 20/10/2021 7:51 am
