Benchy 1st & Only Print
3dJoe
(@3djoe)
2 weeks in as a first time 3d printer owner.
Printer: Prusa Mini+ (not Kit)
Filament: SunLu PLA+ Grey
Dryer: SunLu S1 @50C
gcode: 3DBenchy_PLA_150um_MINI_2h (came with the Prusa Mini+ USB stick)
Opublikowany : 14/05/2021 8:10 am
1 ludzie polubili
RE: Benchy 1st & Only Print
A little stringy but not a bad first print.
Opublikowany : 14/05/2021 10:57 am
1 ludzie polubili
3dJoe
(@3djoe)
@cwbullet
First print of Benchy. I'm happy with the result comparing it to a lot of the Benchy prints found in 3d printer reviews on Youtube.
Why is stringy bad? And what are typical causes? Thanks!
Opublikowany : 14/05/2021 12:25 pm
sandysasmita
(@sandysasmita)
i see some tiny holes in your benchy. (gcode from usb is presliced for prusament/prusa pla and might not suitable for other filament)
tip: if your other print result have holes in print wall, try to overrides retraction length to 2 mm. if the result is good, don't change it.
my mini have problems with sunlu and esun, after change that setting, no more holes and less stringy.
Opublikowany : 14/05/2021 4:27 pm
1 ludzie polubili
3dJoe
(@3djoe)
@sandysasmita
Can you share your Sunlu PLA+ profile settings?
Opublikowany : 15/05/2021 2:00 am
