Bad Adhesion
johno
(@johno)
Bad Adhesion
I finally got my Mini Plus my first good print the Nut .But after that I can not get anything to stick . I have cleaned the bed and used Magigoo glue and turned up bed heat .But models are still coming lose on bed . Any Help Thanks
Opublikowany : 05/12/2021 2:45 am
Kalimero - Jan Fiala
(@kalimero-jan-fiala)
RE: Bad Adhesion
If your print surface is perfectly clean and all grease has been removed by wiping it with a paper towel soaked in isopropyl alcohol 90% and if the first layer height is set up perfectly, yet your print still does not adhere reliably to the print surface, check out First layer issues: https://help.prusa3d.com/en/article/first-layer-issues_1804
Nejsem zaměstnancem Prusa Research.
Opublikowany : 05/12/2021 8:40 am
BogdanH
(@bogdanh)
RE: Bad Adhesion
IF your print sheet is clean (& without fingerprints) and you have done first layer adjustment properly, then no glue is needed.
[Mini+] [MK3S+BEAR]
Opublikowany : 05/12/2021 9:07 am
