ASA Pillowing?
rockytoptim
(@rockytoptim)
ASA Pillowing?
So I have started printing in ASA on my mini.  I have had very good sucess with small is parts.  but larger parts longer thatn 50mm have pillowing on the top layer.  The first and bottom layers are fine.  How do I correct the top layer issues.  I read some pillowing issues on the web and looks like I could adjust the fan speed.   What fan speed are you guys using for ASA.   Below is top and bottom layers of part that has the issue.
This topic was modified 5 years temu by rockytoptim
Opublikowany : 24/06/2021 7:26 pm
towlerg
(@towlerg)
RE: ASA Pillowing?
If the second picture is of the first layer, you have a seriously dirty build plate or something. Fix that first.
Opublikowany : 25/06/2021 9:09 am
Lichtjaeger
(@lichtjaeger)
RE: ASA Pillowing?
Those are warping problems. You should get an enclosure for your printer and look for guides for slicer settings to reduce warping.
Opublikowany : 25/06/2021 9:41 am
rockytoptim
(@rockytoptim)
RE: ASA Pillowing?
Posted by: @towlerg
Sorry for the bad picture.  I took the picture after I had been doing some sanding on a woodworking project and didn't get all the dust of my hands when I picked up the part from my desk.  I always clean my build plate after every print with alcohol.
Opublikowany : 25/06/2021 1:47 pm
rockytoptim
(@rockytoptim)
RE: ASA Pillowing?
Posted by: @lichtjaeger
I have a Lack enclosure.  On the Slicer settings that's why I am here some.  Some slicer suggestions were the fan speed, so I was hoping someone could give me estimate on the fan speed I mentioned in my OP.
Opublikowany : 25/06/2021 1:52 pm
Dr. Kropp
(@dr-kropp)
RE: ASA Pillowing?
Whenever I have seen a top surface like that it is because a portion of the model separated from the base and started to curl upwards. I have not had any luck with ASA on the textured sheets (literally had a 6 hour print fail 30 minutes ago because I was too lazy to switch to the smooth steel sheet).
Opublikowany : 25/06/2021 8:05 pm
towlerg
(@towlerg)
RE: ASA Pillowing?
Posted by: @rockytoptim
Posted by: @towlerg
Never the less, first layer should be even with no irregularities (not most of the right hand side and tp third). IIWY I'd do a search in this forum for "dish soap", many prefer a dish scrupper, soap and boiling water. I do that every 10/20 prints with a quick wipe left-right front-back with alcohol every couple. The argument is that alcohol just moves the contaminant about.
Opublikowany : 26/06/2021 11:49 am
