ABS not extruding consistently
Due to a mishap with PETG filament, I had to change nozzles. I now have a 0.4 mm hotorange3d brass nozzle on my mini.
Upon calibrating first layer, ABS won't print a consistent line all the time. Especially in the first 20cm of thread, there is beadiness
in the laid down thread.
Also, when I print a 3Dbenchy, the hull is not smooth but slightly bubbly. And benchy is about 0.15mm too small in most dimensions.
I lowered the printhead but to no avail
What parameter do I need to change?
kind regards,
Marout
Opublikowany : 25/08/2020 6:42 am
