0.6 Nozzle Problems
powtac
(@powtac)
0.6 Nozzle Problems
Setup:
Prusa MINI with 0.6 Nozzle.
Firmware 4.0.5
Bootloader version 1.0.0
Buddy board 1.0.2
Prusa Slicer 2.2.0 (find the gcode attached at the end)
After I switched to the 0.6 Nozzle I have massive problems to get good results, as you can see in the piture below. The two parts in the front starting to have from the height of about 5 mm very bad lines. I realized it 5 mm later and I set manually the temperature from 215 to 220 which seemed to solved the problem a little bit, but still not perfect results.
I removed the 0.6 nozzle again to make sure it was fitted and it was, as you can see in the picture below:
No blue filament on the thread.
Ce sujet a été modifié il y a 6 years par powtac
Publié : 24/05/2020 7:02 pm
powtac
(@powtac)
RE: 0.6 Nozzle Problems
... adding more information:
Slicer with default setings (including 0.6 nozzle)
Find the gcode here: https://gist.github.com/powtac/5ea2c492e65cbc48a9f6e5c4a7fc6f3e
Using the OctoPrint 1.4.0 on OctoPi 0.17.0 with serial connection.
So what could be the issue here?
Ce message a été modifié il y a 6 years 2 fois par powtac
Publié : 24/05/2020 7:15 pm
powtac
(@powtac)
I did use some noname filament with the 0.6 nozzle first and had bad results as well. The problem mainly was, that the temperature (215 degrees) was too low. So I raised it for the noname filament to 240 degrees which seemed to solve the problem but quality was not perfect, so I switched to the Prusa Polymers filament to make sure the issue is not related to the filament.
Publié : 24/05/2020 7:24 pm
wuerfel
(@wuerfel)
Firmware 4.3.1+2759
Buddy board 1.0.5
Prusa Slicer 2.3.0
Is there any solution to this? I have the exact same issues. It seems to be a way too high flow rate. So I thought my idler tension was not properly set and tightened the screw. This slightly gave me better results, but I found my idler tension screw is way too tight now.
I used the guide to set the right extrusion width/ extrusion multiplier or flow rate factor. Printed the cube as vase, measured and got perfect width, but when I print an object, my corners are still bumpy (too much extrusion), I see scar marks on the top layers (too much extrusion) and I have gaps between my top layer lines (too low extrusion) which seems to be an issue with the slicer. I also have the bad starting lines which leave a hole in the outer shell. I tried using extra extrsuion after retraction, but no effect on those gaps. I can't find any settings to dial in different flow rates for different types of extrusion (like walls, top or bottom layers) I can only adjust the diameter of those.
For the moment I will switch back to a 0.4mm nozzle as I can't find any solution to this issue and I spent way too much time trying to get it dialed in.
Any help of advice appreciated.
Publié : 29/03/2021 1:30 pm
