Z-Axis Dust Cover - Drop-in Protection for Core One
Hello Core One community,
I've designed a dust guard to protect the Z-axis openings from filament debris and dust accumulation. After noticing particles collecting in these areas, I wanted a clean solution that doesn't require any printer disassembly.
Design Features:
- Protects all three Z-axis openings (3 guards required per printer)
- Strategic slot allows installation without removing Z-axis rods
- Mounts using existing screw positions - no hardware removal needed
- Does not obstruct Z-axis movement or operation
- Print-in-place design with no assembly required
Installation: Simply slide each guard over the Z-axis rod through the integrated slot and position over the existing screws. The mounting holes align perfectly with the factory hardware.
Print Settings:
- No supports required
- Standard 0.2mm layer height works well
This has been working reliably on my Core One for a week without any interference with normal operation.
Download: https://www.printables.com/model/1337982-prusa-core-one-z-axis-dust-coverguard-set-of-3
Would appreciate feedback from anyone who tries this design. Always looking to improve these practical modifications for our printers.
RE: Z-Axis Dust Cover - Drop-in Protection for Core One
Great solution!
Thanks.
I put these on my printer as I was building (MK4S to Core One Kit) so I didn't even need the slot :). I like the way they fit on the screw heads (nice snug fit) and their unobtrusive appearance (printed in black PLA).
Thanks,
Steve
