Prusa Core One HT – Finally, it's done!
Pagina 1 / 3
jan.d.slay
(@jan-d-slay)
Hello to all Prusa Core One fans,
Before I begin, I would like to say a big thank you to metacollin. Of course, I only found and read your post here in the forum after I converted my MK4 to Core One.
The topic of high temperature, or rather, breaking through the 290-degree nozzle temperature limit, has always been an incentive for me to look into it. Encouraged by metacollin's post, I now considered: buying a used MK4 and converting it as metacollin described, or waiting until Prusa released the HT nozzle plus software.
In short: Last weekend, I asked ChatGPT whether it would be feasible to include metacollin's changes in the latest “stable” firmware 6.3.4. After three days of debugging and adjustments to the source code (without any knowledge of the programming language, mind you), the finished software was released yesterday evening.
I quickly ordered a copper heating block and a PT1000 sensor (as linked by metacollin) from Amazon.
Today was the big day:
  • Copper heating block and PT1000 sensor installed
  • Seal on the circuit board broken
  • Firmware loaded onto formatted stick
  • Modified firmware “HT450” installed.
  • Done
Finally, here's the video:
Postato : 23/02/2026 7:05 pm
3 persone hanno apprezzato
Nice! Now that you have done it, could it be ported to 6.4.0 (and future firmware versions) easily? Any specific reason why you did not start based on 6.4.0? For the Core One it seems to be a reliable firmware, apart from the bootloader blue screen.
As a side note, did you get ChatGPT to actually point you to the relevant files and functions in the source code and suggest what to change? I have tried this a couple of times -- with ChatGPT and Grok so far, using registered but free accounts -- and was quite disappointed: They just kept directing me to the Github repository in general, rather than searching it and suggesting specific files and function or variable definitions. I was wondering whether there are access limitations (technical or contractual) on Github which prevent the LLMs from doing that?
Postato : 24/02/2026 7:17 am
jan.d.slay
(@jan-d-slay)
Hello Jürgen. I've already thought about that. I assume that upgrading to version 6.4.0 is no longer an obstacle.
As with the Prusa XL, I was also not satisfied with 6.4.0 on the C1. I only used version 6.3.4 because I felt I had more success with phase stepping when searching for noise in the Y-axis than with the current firmware.
I have been using the paid version of ChatGPT for quite some time. At some point, I couldn't get any further with the free models. In the beginning, there was only one mission: Chat GPT was supposed to “guide” me so that I could understand for myself what I had to do to get functional firmware.
However, it quickly became apparent that my lack of programming knowledge and incorrectly phrased questions to ChatGPT led to a dead end. That changed when I added the link from Github from metacollin and wrote that I only wanted the PT1000 sensor evaluation in the Prusa firmware 6.3.4. And then it started, and ChatGPT made a 180-degree turn toward the finish line.
I was impressed by the evaluation of the failed attempts to create the firmware on the PC. For every error that appeared in the console, a change or improvement was made after I told ChatGPT what error messages appeared after the last command.
Without ChatGPT, it would have taken me months or even years to understand how Prusa's source code works. But I must also say that if you have learned programming languages and know how to write programs, it is safer and easier than using AI.
Unfortunately, I don't have that mindset, and AI was the missing piece of the puzzle to get me to my goal.
Postato : 24/02/2026 8:26 am
2 persone hanno apprezzato
gb160
(@gb160)
RE: Prusa Core One HT – Finally, it's done!
I've done it a few times now, but not for firmware, but to add a few QOL improvements to Prusaslicer. (inner/outer/inner wall order, and option to define the ironing angle)
I find the best at this sort of stuff by far is Claude.
The quickest route is to work out yourself exactly what files hold the code that you will be adding to or changing. Then describe what you're trying to achieve in your prompt, and provide the raw url links to the files that need altering.
I was amazed by how quick and painless it was to achieve the desired result...I know the basics of many programming languages, but this (with C++) was way beyond my pay grade.
Postato : 24/02/2026 8:42 am
1 persone hanno apprezzato
Utenti
Is that a bambulab build plate?
Postato : 24/02/2026 10:16 am
Posted by: @gb160
Indeed, Claude seems to be ahead of the competition when it comes to programming. My wife uses Claude Code for work. I have not talked myself into any paid AI subscription for hobby purposes yet, but when I do so, it would probably be for Claude as well. (I also like Anthropic's corporate approach to AI -- they openly discuss the risks and how to mitigate them, where other vendors seem to focus on the hype.)
I would hope that getting a handle on a large existing code base -- e.g. scanning all source files to find the relevant definitions for some intended change -- should be well within the capabilities of an LLM. Seems even easier than coding? Architecture of complex, entirely new systems is a different matter, but that is not what we need here.
Postato : 24/02/2026 10:26 am
gb160
(@gb160)
Yeah it's hands down the best.
The infuriating thing is I have free enterprise access to ChatGPT, but honestly its not great for coding...its great simple coding, and other things but my primary use for AI these days is coding thats way beyond what I could achieve with my own knowledge/skills, so I basically have to exhaust my cap with Claude, then he kicks me out for six hours, then I go back to it.
I cant emphasise the time I've wasted with ChatGPT (going round in circles trying to achieve a simple task), and I've concluded I'm better off waiting for Claude to let me back in.
A simple trick I've learnt with Claude is to start your session with him around 5 hours before you really want to get busy with it just give him a vague outline of what you're planning to do, then after 5 hours hammer him until the cap expires...then when he kicks you out you'll only have to wait around a hour or so before the cap resets. Its a PITA, but that way you can get virtually double the cap per session (I hope that makes sense)
Postato : 24/02/2026 10:35 am
jan.d.slay
(@jan-d-slay)
Cool... I'll give Claude a try. I hadn't heard of him until today.
Postato : 24/02/2026 11:39 am
I'm a professional Java/Python/C++ developer and until AI our primary resource is/was StackOverflow. I might get stuck on say how to write a mocked unit tests, go onto Stack Overflow and maybe find an example that works. StackOverflow is a place where you ask a question: "How do I do X?" and you get answers where the participants can upvote or downvote the answers. Even if I get an answer to a similar question,  at a minimum I would need to modify it get it to do what I needed. Still, that would require having a deep understanding how the code in question functions.
Recently they've rolled out Claude at work. I've been using it to generate documentation or some of the other aspects of coding which are tedious like writing unit tests. We've had mediocre developers leaning on it heavily to the point where they don't understand the code that was generated. Sometimes this can be amusing. Example Claude spat out:
if (a != b) || (a == b) {
Which is funny because it's a tautology, i.e. it's always true. The developer didn't think to question this.
Postato : 24/02/2026 4:43 pm
Cédric
(@cedric)
This is really interesting, i wonder how this will differ to prusas own firmware that will come with the HT hotend? Any ideas?
How hot do you dare to go, would be really interesting to see how it prints PPS-CF at say 330degC and maxed out bed and chamber temp, more temp than that isnt really that usable, with current filaments at least.
I tried several AI services at work where we have many of them available. I also found Calude the best when it had to build a complete software for a data analysis tool from scratch, though Im not sure how to best work with big files because it gets very unstable.
Postato : 26/02/2026 7:56 am
jan.d.slay
(@jan-d-slay)
My first test print was positive and exactly as I had hoped, but unfortunately there are now problems with the filament being too stiff.
As hyiger has already written, it is difficult to insert the filament into the Nextruder, guide it through the filament sensor, and push it into the nozzle for extrusion.
In my opinion, there are two fundamental problems:
1. The pre-tensioned shape of the filament wound on the spool causes the bend of the filament to be twisted 180 degrees in front of the drive wheel in the Nextruder with the original filament feed. The filament has no choice but to break at the deflection roller, especially when the bend becomes tighter as there is less filament on the spool.
2. The placement of the filament feed is therefore unsuitable for very stiff filaments. Instead of on the right side, it would have to be placed on the left side so that the bend of the stiff filament is on the same side as the Nextruder gear.
This is also the reason why I was able to print the PPA-CF in the Bambu Lab X1C without any problems, as the PTFE tube is positioned in such a way that the filament inevitably had to lie in the shape of the drive gear.
Let's see how I can solve this.#
This step of adjusting the firmware so that we could finally exceed 290 degrees was important to me in order to finally reach the upper temperature limit and significantly improve layer adhesion once again.
To test 450 degrees, a few changes to the hardware are still needed.I will put the fork on GitHub online in the next few days; I just need to find the time for everything first.
This will continue to be exciting.
Postato : 26/02/2026 8:32 am
Cédric
(@cedric)
I print Siraya PPA-CF on a std printer, and it works well now. The issue is as you say the bowden bend in combination with the idler arm. I found two solutions that work, either you reroute the bowden 180 degree, so the filmanet enters more with its natural bend. Or you swap to the single wheel idler arm. I run the single wheel arm and have no issues at all with PPA-CF or any other brittle materials. Though TPU might be diffcult, havent tried that yet. There is a new quick swap arm that could be a s solution for that.
Postato : 26/02/2026 9:04 am
Cédric
(@cedric)
Here it is:
https://www.printables.com/model/1236396-single-wheel-nextruder-idler-lever-for-brittle-fil
If i were to make the mod again i would try the quick swap version:
https://www.printables.com/model/1446937-quick-swap-dual-and-single-idler-lever-for-core-on
Postato : 26/02/2026 9:08 am
jan.d.slay
(@jan-d-slay)
Hello Cédric
Thank you for your tips. I actually already had the two idlers from the two links in my list, but I had forgotten that I had already saved them.
I'll try to solve the problem using the idler first before I rebuild everything from right to left.
Thank you!
Postato : 26/02/2026 10:40 am
I’ve been able to print PPA-CF by using my own Bowden setup and feeding it in over the side and underneath the top. Problem is 290C at he nozzle is really not hot enough and I have to drastically lower the flow rate. I would export the HT hot end but in a month (hopefully) I’ll be removing the Nextruder and replacing it with the INDX system.
Postato : 26/02/2026 10:51 am
jan.d.slay
(@jan-d-slay)
Hello,
The idler, with only one roller, works perfectly. After the conversion, I clamped in some leftover undried PPA-CF and printed a Benchy.
320 degrees without any problems from start to finish, even the first roof lines of the boat.
Untidy and a lot of ozzing, but once again a new before-and-after comparison.
Heat protection for the heating block is coming now, finally!
Z
Screenshot
Postato : 01/03/2026 4:01 pm
jan.d.slay
(@jan-d-slay)
Posted by: @cedric
Here it is:
Thanks again for reminding me. It's hard to believe how easy it was once the modified idler was installed.
And I wanted to rebuild the entire filament guide 😉
Postato : 01/03/2026 4:03 pm
Utenti
Undried is right.  Impressive for undried filament.
Posted by: @jan-d-slay
Hello,
Z
Screenshot
Postato : 01/03/2026 4:25 pm
PPA-CF I’ve found needs to be printed while drying, preferably at > 80° but then with a 290° nozzle it’s not really usable (in my opinion)
Postato : 01/03/2026 5:47 pm
Cédric
(@cedric)
Printed right out of the box on prusa nylon settings, have you modified anything except temps, i never put effort into calibration of the print parameters? This cnc kitchen test hook could easily lift 25kg printed standing up, so layer adhesion seems decent already at 290, 300+would make it even better. Would probably need to be dried if i want to use that spool again, been sitting on the shelf for a while. Glad it worked with the idler arm, i always try to keep mods to the bare minimum 🙂
Postato : 01/03/2026 10:03 pm
Pagina 1 / 3
