More and better LEDs in the core one...
Stránka 2 / 2
Raaz
 Raaz
(@raaz-2)
RE: More and better LEDs in the core one...
But I just solved this problem...This constant knocking is caused by uneven tension of the belts on both sides
Nice "in other words" for the manual 🙂
I'd like to add to this sentence: are you sure, that your belts now have the same Hz? When my belts are both at 85 Hz, the end-stops aren't synchronous.
So when I'm doing it like you're describing, I end up with my currently used tensions of 81/86 Hz. The homing is, as you say, fast and only knocks about 5x.
Btw: I'm wondering that I can already find lots of mods like dust protection for the bottom, but no dust filter for the top intake and no "silence" mod for the homing.
I'll have a go with 1-3 layers of 95A TPU on the end-stops and report back in a few days. Since not all of the print bed area is used, it shouldn't matter if it's 100% precise?
It just needs to home well.
Napsal : 12/05/2025 1:21 pm
Sembazuru
(@sembazuru)
Posted by: @tomtim
Hi Sembazuru,
yes, 24V to connect with a fuse to the powerboard 🙂 We make the same with our set if it is delivered 🙂
I think either you or I misunderstand. By "powerboard" do you mean the extension board mounted above the xBuddy in the enclosure, the power input connections on the bottom of the xBuddy, or the power output connections of the power supply?
My thought was to desolder the original Prusa white LED strip from the cable, and attach the cable to a new white COB strip. This would then plug into the LED connector on the extension board. I was wondering what the LED drive voltage at that connector is.
I finally broke down and found the schematic and verified that both the white LED and the RGBW LED strips are driven by 24V (from the red extension wires). I haven't looked, but I wonder if there are RGBW COB LED strips on the market that have individual R, G, B, and W lines (instead of a single data line)...
See my (limited) designs on:
Napsal : 13/05/2025 5:08 pm
Mercur12
(@mercur12)
@Sembazuru: tomtim connected the LED to the PSU !
As far as I know, COB LEDs are only available in white, but in various color temperatures and in 12V and 24V.
If you replace the original LED strips with COBs and use the original connector (as I intend to do), You shouldn't draw significantly more power than the original LEDs.
The photo shows the COB LEDs available, for example, from LED-Konzept.de.
Thanks for the schematics ! Vary interesting. Are there schematics of the whole thing also ?
Regards
Napsal : 14/05/2025 7:04 am
Mercur12
(@mercur12)
Sorry, I have to contradict myself! 🤔
Unfortunately, my previous post can't be deleted, hence this correction!
Further research has revealed that COB LED strips are indeed available in RGB. (See attachment)
Napsal : 14/05/2025 7:21 am
Sembazuru
(@sembazuru)
Posted by: @mercur12
I don't know of a full unit wiring diagram, but there are schematics of the individual boards. I use this page as a reference to find Prusa schematics (instead of surfing through all the Prusa GitHub repositories):
https://www.prusa3d.com/page/open-source-at-prusa-research_236812/
This post was modified před 12 months by Sembazuru
Napsal : 14/05/2025 4:52 pm
1 lidem se líbí
tomtim
(@tomtim)
Here an update... the better LEDs ... on all 4 Sites... direct glued on the housing.
Napsal : 28/05/2025 11:18 am
4 lidem se líbí
Sonnenwolf
(@sonnenwolf)
Posted by: @tomtim
May i ask which LED strips you used? I find it interesting because the interior of the Core one is to dark for my taste and probably for the cam i want to install.
Napsal : 31/05/2025 7:10 pm
Mercur12
(@mercur12)
@Sonnenwolf: Thread nicht gelesen ?
Prusa-LED-Kabel vom Streifen ablöten und an andere (COB oder normale 24V)-Streifen anlöten. Fertig. siehe oben. Die Mehr-Leistung ist unkritisch.
Napsal : 19/06/2025 4:17 pm
Sonnenwolf
(@sonnenwolf)
@Mercur12: Doch ich habe den Thread gelesen.
Soweit ich tomtim's post verstehe, hat er nochmals die Leiste getauscht und ich wollte nur wissen welche Strips er jetzt benutzt.
Zwischenzeitlich habe ich einen Post von ihm in einem anderen thread gefunden wo er einen strip benannt hatte.
https://forum.prusa3d.com/forum/postid/750935/
This post was modified před 10 months by Sonnenwolf
Napsal : 20/06/2025 6:22 pm
Protoncek
(@protoncek-2)
Guys
So you say that you connected additional led's parallel with existing on the same output? I'm looking schematic and, unless i'm missing something mosfet for white led's is MMBF170, which has maximum current 500mA. So, i guess that anything with decent power should be connected via separate mosfet, otherwise built-in mosfet will sooner or later burn-out...
I wonder how much original led's draw... i'd measure, but i'd have to turn around printer, remove electronics cover...
Napsal : 13/07/2025 5:56 pm
Mac-N4MCC
(@mac-n4mcc)
I had a ton of problems with the C1 in the beginning, then I loaded all the Prusa Research configs into Slicer and all that banging and other problems went away when I use them/
Extra HAM (and eggs some say) Radio - N4MCC
Napsal : 09/12/2025 4:17 am
NickAtNight
(@nickatnight)
Yes, it is a pretty quiet printer.  The loudest part is when the heads move fast from one object to another.
Napsal : 11/12/2025 6:19 am
Stránka 2 / 2
